Old 08-10-2008, 05:49 PM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Default Oil for nutplates
I can?t find any guidance one way or another regarding putting a drop of oil on the threads before running the bolt into the nutplate. Anybody have any guidance?
Bob Markert
RV8 Wings slow build
Old 08-10-2008, 05:58 PM
RV8N RV8N is offline
I use a dab of boelube on every screw before I run it into the nutplate. Be especially careful with stainless hardware. It can gall after just a few runs in and out. You can get boelube from Avery's or most of the other A/C suppliers.
Karl
RV-8 #80240 SOLD
1999 BMW R1100RS
Old 08-10-2008, 05:59 PM
vic syracuse vic syracuse is offline
Super Moderator
Use Boelube. Especially on #6 screws. No mess like oil. Just rub each screw/bolt into the boelube and the screw will trun musch easier. The friction heat actually helps melt the boelube.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 08-10-2008, 06:40 PM
AlexPeterson's Avatar
Or use wax from a toilet ring. Enough to last 100 airplanes for a buck.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 08-10-2008, 07:03 PM
terrykohler terrykohler is offline
For fasteners in the floor pans, rear baggage bulkhead, wing tips and other non-critical areas, I ran a tap thru the nutplates. They are still left with a small amount of prevailing torque, but it sure makes life easier. You should consider this, especially for fasteners that you will be installing and removing fairly often. Incidentally, if you intend on using lube on fasteners that you plan to run up to torque spec, don't. Most fastener specs are written without lube, unless a very specific type and specific amount is stated. As for stainless fasteners, I would suggest that you tap the nutplates wherever possible. As pointed out, stainless is very abrasive, and will lead to galling and thread stripping, especially on multiple re-use or with a long run-down (you can feel the heat right thru the bolt.)
Terry
Old 08-10-2008, 07:24 PM
bobmarkert's Avatar
Thanks guys, I have boelube and will use that. I'm just installing the nutplates on the spar fot the tank attachment. I will run a tap through the non structural nutplates (wing tips etc) and espically for the SS ones.
Bob Markert
RV8 Sloooow build wings
