Old 08-10-2008, 08:31 AM
Don Patterson's Avatar
Don Patterson Don Patterson is offline
Default 4 into one exhaust on 7a???
I would like to put a 4 into one exhaust on my 7a but can't seem to find a manufacture. The routing of the exhaust around the nose wheel assembly seems to be a problem. I have seen other tri gear Experimental (not RV?s) with one large exhaust tube.
Old 08-10-2008, 01:27 PM
TGRV7 TGRV7 is offline
Default AWI
I believe AWI has a 4/1 for the Nosegear setup.
http://www.awi-ami.com/
Give them a call
______
TGudz
EP, TX
RV7
Wire/Elec Phase
Old 08-10-2008, 04:14 PM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Give them a call
Hmmm...they must have hid it pretty good on their website.
All their 4 into 1 systems on their site are for taildraggers (6,7,8,9),
no "A" models listed.
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
Old 08-10-2008, 05:01 PM
sjhurlbut sjhurlbut is offline
I looked into this company for 4 into 1. As far as custom goes seemed like a good company. They send you PVC piping and you install it as you please, send it back to them and they fabricate it. This is my plan for a IO-390 RV-8.
http://aircraftexhaust.net/custom_exhaust.html
Steve
Rv7A Flying
Old 08-11-2008, 01:35 PM
DSmith DSmith is offline
Hi Don, I have one of AWI's 4 into 1 exhaust but I have not flown yet so I don't know how well it will do. They had a version of the 4 into 1 up on their website at one time but have taken it down. The original exhaust they sent needed a couple of tweeks to make it fit. When it came back they had make a completely new design. I had to send it back for couple of minor tweeks and then it fit great. My engine is a TMX IOF-360 which is basically like an IO-360 M1 (Horizontal intake cool air sump). There is so many Lycoming engine configurations and a couple different cowlings for the 7A that it makes it difficult to fit the 4 into 1 but mine looks great. The collector on my exhaust is back at the exit of the cowl so I'm hoping it won't block too much of the air flow.
The AWI folks were great to work with and their workmanship is excellent.
AWI 1-800-597-4315
Danny
RV-7A
Old 08-11-2008, 04:56 PM
Danny: Thanks for the tip on AWI. I called them today and there not making any RV*a exhaust anymore because of the nose gear. It is just to much to work around they said. Although they told me that the president of Lycoming has there 4 into 1 on an 8a that he owns. I won't give up yet....I will keep searching the internet. Thanks again.
Don
Old 08-11-2008, 08:30 PM
Mel's Avatar
Mel Mel is offline
Default Call Larry Vetterman
I'm pretty sure that Larry has a 4 into 1 setup for a -7A. Give him a call. 605-745-5932
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-11-2008, 09:18 PM
Thanks Mel: I will call him tomorrow for sure. I will post his answer.
Old 08-12-2008, 08:18 PM
nedrose nedrose is offline
Last year I worked with AWI trying to develop a 4- -1 for my 7A. After 3 or 4 tries, they gave up, at least for a while. There just was not enough room for the collector. They were good to work with and the quality was next to none. After all was said and done, I did get stuck with shipping cost for sending it back the last time.
Ned Rose
RV 7A
42TD
Old 08-13-2008, 08:37 PM
I called Larry Vetterman about exhaust system on my 7a and found that this guy knows his stuff. He not only builds, but flight tests systems to determine there performance. He will build you a system that won't leave you stranded at some ramp miles from home. My purchase will be a Verrerman exhaust for my RV.
Don
