Soldering iron
Originally Posted by flickroll
How easy is it to repair a crack in a canopy? The crack is about 2" long and has been stop drilled. What materials are used (is there a kit for this)? How difficult is the repair? How noticeable would the repaired area be? Thanks
Sad to say, before I knew about Weldon, I put a crack in my canopy while enlarging the hole where the latch goes. We stop drilled it and used a hot soldering iron to melt the crack together.
Then we sanded and polished the area. Not the ideal repair, but it did work.
YMMV
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
