Old 08-09-2008, 07:46 AM
N941WR's Avatar
N941WR N941WR is offline
Default Mode S code?
In reading the tread on ATC violating us a discussion on the Mode S identification code came up.
In checking the entry for my plane on the FAA's web site, a mode S code of 53211343 is listed.
N941WR only has Mode C, as far as I know. (Garmin 320A transponder with the Dynon mode C module.)
Where did that number come from? Is it possibly a default number? At no time did I register my transponder with the FAA; however, the guy who did the Mode C check did take the serial number with him.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-09-2008, 07:59 AM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Default Mode S code
Originally Posted by N941WR View Post
Is it possibly a default number.
My bet, if it is like up here in Canada, is that it is a default code assigned to your registration. If you were to get a Mode S transponder, that would be the code assigned to it. My friend's C-150 with the lowly Mode C transponder has a Mode S code assigned to it.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 08-09-2008, 08:10 AM
osxuser's Avatar
osxuser osxuser is offline
Every airplane registered has a mode S code associated with it. Doesn't really mean squat until the FAA decides to mandate Mode S or ADS-B. Unless of course you CHOOSE to get mode S
RV4 wing in Jig @ KPOC
RV7 emp built
Old 08-09-2008, 10:17 AM
Ironflight's Avatar
VAF Moderator / Line Boy
When you install a Mode S transponder, you enter the code that is listed on your registration into the unit as part of the set-up process. That is why they arbitrarily assign a code to every aircraft - most of them just aren't being used.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
