Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 08-08-2008, 08:08 AM
Default Parting out a Subaru H6...
Anybody hanging in there with the H6 and in need of a parts survival kit, send me a private message.
Everything will go from injectors to a service manual to an OBD scanner....cheap.
I do believe I cooked the engine last summer and what's left will go to a scrap yard.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 08-08-2008, 08:53 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Sad to hear David. You were one of the few putting a lot of hours on a Sube and telling the whole truth about your experiences. Are you going to be able to get used to a Lycoming again?
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 08-08-2008, 06:38 PM
Yukon Yukon is offline
Banned
Sorry for your bad luck, David. May I recommend a Lycoming?
