First make sure that you want to do this. Do you normally fly solo? If so then you want the trim to be probably where it is. Without a rear seat passenger, you will require less "down" trim. If you do decide that you want the trim condition for 2-up, just try adding a little at a time. I wouldn't add more than 1/8" at a time. Maybe even 1/16".
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
