Old 08-05-2008, 10:20 PM
Michael Burbidge Michael Burbidge is offline
Default Safety wire size and type...
I have to safety wire the trim tab hinge pin. I've looked in all my books and in the Van's instructions and can't find any information on the size and type of safety wire that should be used for different applications. I have some good instructions on how to safety wire.
What kind and size of wire should I use on the trim tab hinge pin?
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 08-06-2008, 06:21 AM
FredMagare FredMagare is offline
I have two spools of safety wire: .041 and .032. I used a piece of the .041, trimmed the pig-tail down (after twisting), and bent it back where it wasn't going to hang-up on anything.
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 08-06-2008, 06:28 AM
Mel's Avatar
Mel Mel is offline
Typically .032" can be used most places on the RV with the exception of the prop which needs to be .041".
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-06-2008, 08:43 AM
scard's Avatar
scard scard is offline
fyi. My Hartzell HC-C2YL-1BF manual says to use .032" safety wire on the bolts. I read that right out of the manual sitting in my lap. This is the prop for the O-320. Is there a reason we should be using bigger wire for this prop?
Scott Card
CMW E-Lift
Old 08-06-2008, 09:10 AM
Mel's Avatar
Mel Mel is offline
Actually, I was thinking F/P for .041".
Old 08-06-2008, 09:31 AM
kentb's Avatar
kentb kentb is offline
Red face #$@#$@!!!!
No wonder that my plane came out a little heave. I use .041 instead of .032 on my prop.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
dicer dicer is offline
I think most all safety wire is stainless steel. Something like 304. I got some at a local bolt fasener supply place called Tacoma Screw, it said aircraft on the can. I have an application around a prop governor that needs .020 wire some pretty small holes in screws.
