Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 08-04-2008, 12:00 PM
Juicegoose Juicegoose is offline
Default Garmin Handheld not acquiring sat signals
Guys i've had a Etrex Legend for a couple years now and justrecently thought i'd try and keep it with me in the plane for a backup. Problem is i can't get the thing to acquire satellites. I want to say i read a post about some other guys that have had the same problem. This isn't an aviation based gps just a little camping handheld.
Old 08-04-2008, 01:35 PM
Bruce Reynolds's Avatar
Bruce Reynolds Bruce Reynolds is offline
Default I had the same problem
My 396 would not aquire satelites so I called tech support. There is an autolocate feature on mine. Check your manual, you may have the same thing.
Bruce Reynolds
RV-6A
Bruce Reynolds
RV-6A
Old 08-10-2008, 10:08 PM
AnthonyNalli's Avatar
AnthonyNalli AnthonyNalli is offline
The other week I had zero satellites on my 496. This was the first time it ever happened. It turned out not to be a GPS problem at all since it was fixed by cleaning the contacts within the connector of my remote antenna.
Anthony
Read 'Close Calls' monthly at http://CloseCalls.PCAS.ca
