Old 08-03-2008, 02:13 AM
ao.frog ao.frog is offline
Default Power chart for an Extreem IO-360 or Superior IO-360?
Hi.
I'm just starting the breakin now, and the Eagle Engines manual says to start leaning to approx 75 ROP after the first two hours of flight and to fly at 65-75% power until breakin has occured.
Does anyone have a powerchart for this engine?
(IO-360-B1AD2 w/ dual P-MAGS & Roller Lifters, 180 HP, 8,5 compression)
It's based on a Superior IO-360, so I guess I can use a chart for that one as well?
I'm aware of the "48 rule", but after searching this forum, it's seems to me that a chart would be more accurate than the 48-rule.
Thanks.
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
