Old 08-02-2008, 07:03 PM
dan carley dan carley is offline
Default 0320 clyinder question
does anyone know what to torque the clyiners to on a 0320-e2d 150 hp engine.
thank you
danny
Old 08-03-2008, 01:49 AM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default Yes
thank you
danny
Danny,
The information below is taken from the Lycoming table of limits publication #SSP1776 page 1-35.
1/2" cylinder hold down nuts - 600 in lbs.
3/8" cylinder hold down nuts - 300 in lbs
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 08-03-2008, 09:22 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Get the Lycoming literature on hand and use it. If you're torquing cylinder base fasteners, you need to use and have the info.
We live by (and are regulated according to) the reputation created by homebuilt aviators. Let's not give the feds any reason to push their noses farther into our world by creating situations that give them "justification" for more regulation. I.e., don't be torquing critical engine fasteners based only on info gathered from an aviation discussion board alone. Get the literature.
Nothing personal, Mark. Just making a point about using and obtaining critical information.
Good luck with your work Danny.
Bryan
Houston
Old 08-03-2008, 09:35 AM
Aden Rich Aden Rich is offline
Default Cylinder torques
Let's not forget the sequence to torque each nut on the cylinder base, it too is critical.
Old 08-03-2008, 11:53 AM
Mark Burns's Avatar
Default good points
Low Pass and Aden,
Very good points.
I sent Danny (last night) via personal email, links to .pdf's on the net of the overhaul manual, table of limits and parts catalog for his engine.
I didn't post those links here as I was afraid it could overload the server and cause the owner to remove the files.
Mark
Mark Burns
Ruston, Louisiana
FFI FL-24
A&P
Old 08-03-2008, 04:42 PM
Default clyinders
thanks everyone for the responce. my a&p asked me to find out because his books were just stolen, however my other rv-4 friend had all the manuals so we could do the job. we do pretty much by the book out here in ny. don't need to give the faa ammo to fire at us.
thanks again
dan carley
RV-4
N14FT
