Old 08-01-2008, 09:07 AM
idleup idleup is offline
Default Cover for Airflow Performance Fuel Pump...
Does anyone have pictures or even better, plans, on building a cover for the AFP fuel pump? I am using the Andair valve so it anyone has a similar configuration I would like to see it. I cant decide whether using aluminum or fiberglass would be best to create this part...
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 08-01-2008, 10:13 AM
Sparky's Avatar
Sparky Sparky is offline
When ordering the AFP fuel pump through Vans, the pre-made cover comes with it. For the fuel valve, I used the Vans supplied mounting plate drilled to fit the Andair valve. Because I don't have manual trim, I ended up bending the flange for the manual trim knob to 90 degrees and trimmed it to about 1 inch. Then I installed it upside down to mate perfectly with the AFP fuel pump cover.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 08-01-2008, 10:19 AM
I purchased my system with the engine when I bought it through Superior and never received a cover for it. I wonder if they left it out?
Anyway, do you have a picture of it and your installation?
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 08-01-2008, 11:00 AM
Pilottonny Pilottonny is offline
Default Order Van's kit, less what you got!
Matt,
I installed the AFP-pump-kit and an Andair double stack valve, (return lines to both tanks). I used the Vans kit, but had to alter is somewhat because the piping would not fit inside (the litle tapered cover on top). Order the kit from Vans, less the parts you already have and you should be fine.
You can also check out Rene Bubberman's site (Netherlands), he has made a custom cover, that also covers the Fuel flow sensor that he installed in this area.
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 08-01-2008, 10:23 PM
flion's Avatar
flion flion is offline
What Tony said. If you order the Van's FWF for an FI engine, you will get Van's complete setup: tubing, base plate, cover, fittings, and a drawing showing how to plumb it all, as well as another pump w/manifold and another filter. I'm surprised you had that issue with the cover, Tony. When I ran across it, I thought it was just the difference between a -6 and a -7. Frankly, I had other fit issues because the selector mount is different and there is no forward floor plate in the -6, but I made it work.
EAA Technical Counselor #5357
Old 08-01-2008, 10:54 PM
Tony,
That cover is exactly what I need, I just searched VANS site and cannot find it. Does anyone happen to have the part number of it?
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 08-02-2008, 05:54 AM
flion's Avatar
I think you'll have to call Van's; it's part of their FI pump kit. Note, in the picture without the cover, the plate the pump and filter rest on. You probably want that as well, along with the plans for the pump install. And, for the Andair selector, they recommend a special AN swivel fitting - F SWIVEL TEE - to make it easier to plumb the return line.
I had already ordered the FWF kit from Van's, which included the pump install kit (Part 7/7A F.I. PUMP INSTAL) and then Superior included the pump and filter which were exactly identical to what Van's sent me. So I used the parts Superior sent with the Van's kit and the pump and filter Van's sent me are in the box of extra parts to be returned. I'd bet if you call Van's you can get the kit sans pump and filter, much like you can order the FWF and leave parts out.
Old 08-02-2008, 08:42 AM
Yes, I just need the cover since i already have the pump mounted and plumbed...
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 12-07-2010, 10:27 PM
bruceh's Avatar
bruceh bruceh is offline
Default Need a copy of the plans for modifying the center tunnel cover
I'm planning on using the Andair pump. I called Vans and ordered just the parts for the AFP FI pump doghouse. These are the F-7115B-L&R and F-7115C.
The F-7115A bracket won't work for the Andair pump since it has some extra cuts and bends specific to the AFP fuel pump kit, so I'm going to roll my own.
Does anyone have a copy of the AFP FI kit plans they can send me?
I just need some of the measurements off those plans in order to correctly trim down the stock center tunnel cover.
Bruce Hill
2020 VAF donator
Old 12-08-2010, 06:56 AM
flion's Avatar
IIRC, the plans are part of the Van's FWF instructions for the FWF kit. Anyway, you should be able to get them from the factory. Neither Superior nor AFP have anything specific for your aircraft.
Edit: I should read more carefully when I haven't had my coffee yet. I still think you can contact the factory for the plans but I'd advise ordering the F7115A and using it as a base template if nothing else; you might even find that modifying it is easier than starting from scratch. Alternatively, ditch the plans and do your own custom installation, with measurements to suit you. I found the stock installation a bit cramped; if I had used the Andair pump I might have been tempted to come up with a better overall installation.
