07-31-2008, 07:16 PM
Koger Sunshade Installation Instructions
I am investigating installing a Koger Sunshade in my 9A (slider). Does anyone have the instructions in a PDF format that they could send me so I can see what is required for the installation before I purchase the sunshade.
Steve Crimm
Gilbert, SC
Based - SC99
RV-10 N42AH
RV-9A N42AH - SOLD
Europa Monowheel XS N42EU - SOLD
BH-206B3 N42AH- SOLD
BH-206B3 N43AH - SOLD
Track N42AH/N1FLY
07-31-2008, 08:53 PM
Re: Kroger sun shade
I have the shade on my -9A slider. The instructions that come with the shade are very simple and easy to follow. It's expensive but worth it. I have the shade plus dark film aft of the shade, and the same film on the upper portion of the wind screen. I wear a ball cap and still get sunburned. Dan
08-01-2008, 05:31 AM
It's simple....
.......really. The kit comes with the correct drill bit and a tap. Basically, you drill three holes into your canopy center frame rail and then tap it. The holes in the aluminum slide are pre-drilled. Three more holes are drilled on either side of the canopy latch handle, then tapped to hold three velcro spots in place.
After you slide the cloth onto the five or six holders, bent to the shape of your canopy, you put a dab of crazy glue on each one, near the center, to keep the shade from sliding off the rods.
You'll love it in the summer!
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
08-01-2008, 06:22 AM
Mine didn't require drilling
Originally Posted by pierre smith
.......really. The kit comes with the correct drill bit and a tap. Basically, you drill three holes into your canopy center frame rail and then tap it. ......
Regards,
It's double sticky taped to the canopy.
I found getting it properly curved, but not bent a bit iterative
Steve Brown
N598SD - RV9A second owner
O-320, 9:1 pistons, Catto 3 blade
KRHV - Reid Hillview airport, San Jose, CA
08-01-2008, 02:04 PM
You....
.......must have a tip up, Steve. They stick on.
Regards,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
08-02-2008, 06:31 AM
Opps
Its a tip up.
Steve Brown
