Old 07-31-2008, 12:17 PM
docrick docrick is offline
Default Starting on RV-9A wings today
After sorting the dizzying array of platenuts and stuff I'm ready to go. The instructions after countersinking the spar for the AN426 rivets for the platenuts tell us to "spot prime" the countersunk holes prior to riveting.
I've never read anywhere in the wing construction threads where folks have done this. I realize that when countersinking that beautiful gold anodized monster I expose bare aluminum.
Has anyone else "spot primed" these countersunk holes? and if so did you use the same primer you always use or some rattle can that can make quick work of the issue?
Thanks.
Rick
Old 07-31-2008, 12:42 PM
mikehoover's Avatar
mikehoover mikehoover is offline
Rick,
I just used some leftover primer that I had from priming some other wing parts and used a Q-Tip to dab the primer into the countersunk rivet holes along the wing flanges. No big deal.
Mike
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 07-31-2008, 12:53 PM
airguy's Avatar
airguy airguy is offline
I shot it with some NAPA 7220.
Old 07-31-2008, 08:54 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
I bought an alodine pen and used that. If I had to do it again, I'd just hit it with 7220.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 08-02-2008, 08:34 PM
cnpeters cnpeters is offline
Used 7220 also - at first, I tried being clever by shooting through a paper with a hole punched out as a template. Like anyone will see it, so I just sprayed down the row as I became grey and wise .
Carl Peters
St. Louis, MO
RV-9A finishing kit
http://www.mykitlog.com/cnpeters
Old 08-03-2008, 04:07 AM
Robert M's Avatar
Robert M Robert M is offline
Default I did as they suggested
I used a self etching rattle can, taped off the surrounding areas and sprayed a continuous line down the spar.
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 08-03-2008, 06:03 AM
rv9builder rv9builder is offline
I used the same primer I used everywhere else--Tempo Zinc Oxide in rattle cans.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
