Old 07-31-2008, 12:05 PM
Michael Burbidge Michael Burbidge is offline
Default Working with lead counter weights...
Lead is poisonous. What precautions should I take in working with the lead counter balance weights? For the elevators you have to do a bit of trimming.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 07-31-2008, 12:12 PM
rrd1_99 rrd1_99 is offline
Default Wear gloves....
Lead is only poisonous by ingestion. Just wear gloves, and don't eat while you are working on it.
Roger
Old 07-31-2008, 12:19 PM
docrick docrick is offline
Default No need for precautions
Just look at the plans carefully so you don't cut the lead weights wrong and have to order new ones. Don't ask me how I know that it's possible to cut them wrong. BTW those stupid little weights are expensive!
Old 07-31-2008, 12:59 PM
airguy's Avatar
airguy airguy is offline
When you're cutting the lead, it will produce relatively large shavings which are easy to contain and sweep up. You will only have a problem if you produce very fine lead dust that could be inhaled - which you won't need to do, since you don't have to scotchbrite or finetune the edges, just rough it out and wash your hands when done.
Old 07-31-2008, 01:45 PM
SteelMike's Avatar
SteelMike SteelMike is offline
Gloves? uh oh...
Old 07-31-2008, 02:44 PM
Default No worries...
I only recommended gloves in the spirit of the "warning labels" we see today. Unless you are working with it every day for a very long period of time, or ingesting it somehow there is nothing to worry about.
I didn't wear gloves, and THARES NUTTHEENG RONG WIF MEE.
Roger
Old 07-31-2008, 03:01 PM
Rivethead Rivethead is offline
I used to do a lot of lead casting when I was a kid. The tick I developed has only slightly worsend as I grow older. J.K. You should wear gloves if you're worried enough to ask.
Old 07-31-2008, 03:17 PM
Default The whole story
I'm only asking because I was out in the garage last night trimming the counter weights, when my teenage son came out and noticed I'd was working with lead with no protection at all. He's done way too much reading on the internet concerning medical things and generally keeps careful watch to make sure I'm working in a safe environment. He went into the house and told my wife that I was going to die of lead poisoning. To keep the family happy, the rest of the evening I wore gloves and a dust mask, even though I knew very well that those toothpick sized lead shavings were not going to float into the air and be inhaled.
Anyway, he got me just a little bit paranoid.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 07-31-2008, 03:23 PM
Rocket's Avatar
Rocket Rocket is offline
haha there's your whole maintenance department all under one roof.
You- Designer, builder, owner, maintainer
Son- QA, Saftey Officer, Maintenance Contoller/Safe For Flight
Wife- Brains/Manager, Flight surgeon.. (for those unavoidable holes you will put in yourself)
Ian
RV-8 economically on hold... short term hold.
AME2, USN. Now Disabled Vet.
Old 07-31-2008, 04:37 PM
rfinch rfinch is offline
Default Try a protective hand lotion
Try a protective hand lotion, review just posted.
Ralph Finch
Davis, N. California
RV-9A QB Log
