I am planning to use the gasket on the side rails that Dan Checkoway recommends from McMaster Carr. It is the one that has an edge gripper with the seal below that allowing it to be pressed onto the side rails.
It looks like Rudi used the same one. in this pic:
My question is this:
Do you just cut the edge away from the gripper part around the strut brackets to allow the seal to go around these areas?
Does the seal have enough puff to also seal the area up in the front under the frame weldment? My frame weldment has more gap than the 1/8" that I have at the side rails due to the geometry of the entire assembly and the fuse canopy decks.
I also have seen that the struts push the side rails up slightly at the front of the side skirts when I use the jam bolts that everyone is using these days to prevent the canopy from being pushed forward by the struts. This is leaving me with a gap at the front of the side skirts and none at the back.
Maybe this will go away once the front top skin is riveted on because at that point less stress will be on the jam bolts and the face of the frame and more of it will be on the hinge points and sub panel structure where it belongs.
