Old 07-30-2008, 08:13 PM
danielhv's Avatar
danielhv danielhv is offline
Default Think I got the wrong parts or a misprint...
Building a -7. Working on trim tab... plans call for an E-717, and an E-718 which are inboard and outboard trim horns... Problem is, I dont have such a part. I have an E-617 and an E-618... shows that on my inventory sheet as well... of course it could be wrong parts, or simply a misprinted label put on the correct part! So, I'm not sure what the difference, but will these work or do I need to send them back and swap them for the correct part numbers?
Old 07-31-2008, 06:15 AM
flydjd's Avatar
flydjd flydjd is offline
Default Common part #'s from RV6
IIRC they are the common part numbers from the RV6 series that was superceded by the 7 ... a way for Van's to save money for us by using existing parts in the updated design.....check the dwg's and they should look right, then build on !
Regards
David J. D.
RV 7A QB (but possibly slowest builder in Europe !)
Hannover,
Germany
VAF # 776
Old 07-31-2008, 07:18 AM
airguy's Avatar
airguy airguy is offline
Yep, there are a few places where that occurs on the 9 also, sharing parts from the 7.
