Old 07-30-2008, 07:01 AM
Steve Brown Steve Brown is offline
Default Painted my back window
Finally got tired of replacing the duct tape / aluminum foil shade on my back window.
I read the various posts on Plexiglas painting and it seemed like 2 part polyurethane would be best. Unfortunately, what I have read elsewhere is that it should only be sprayed while wearing a positive pressure respirator (which I don't have) and I didn't want to brush it on.
So, I used Rust-oleum "Plastic". I took a few pictures of the process and outcome. The white on the inside is duct tape residue which came right off with WD40:
http://brown-web.net/Flying/painting.htm
Here is what I did:
-Masked off the area
-Sanded the surface with 600 grit sandpaper
-Cleaned with mineral spirits
-Dried well
-Put on 2 coats of black. 20 minutes between coats
-Put on 3 coats of white. 20 minutes between coats
-Let dry one hour then removed the masking
-Let it sit a week, flew yesterday
That is what I did and so far the paint is sticking. I'm not recommending this procedure until I see if its still sticking a year from now.
That last step is probably not necessary, but the can says its a week to full strength.
It blocks light well, but there are some slightly thin areas. Nothing that makes me want to do it over, but next time I'll go 3 coats of black and 4 coats of white.
The white is very reflective and was much cooler to the touch than my unpainted aluminum in the sun yesterday.
I wanted black on the inside to reduce reflections inside the cockpit. This works ok, but the black is a bit more glossy than I wanted. Next time I'll use 400 grit sandpaper (or bigger) so the black will be less glossy.
"Next time" is if this holds up for a while I'm going to do the top of the canopy and take off the Kruger shade. I'll probably do this next oil change if its working out.
Steve Brown
N598SD - RV9A second owner
O-320, 9:1 pistons, Catto 3 blade
KRHV - Reid Hillview airport, San Jose, CA
Old 07-30-2008, 07:35 AM
JHines JHines is offline
Default Looks great
With the black being on the exterior, isn't the interior surafce of the window going to be reflective regardless of how "gloss" or "flat" the paint is?
Jonathan Hines
Charlotte, NC
Old 07-30-2008, 07:43 AM
flyeyes's Avatar
flyeyes flyeyes is offline
It's a little late now, but another method is to paint the inside of the canopy rather than the outside. The plexi will give you the gloss, even if you use "flat" paint. In fact, you can brush rather than spraying, and the outside gloss will still be perfect. It should be much more durable long term.
I wonder what brushed zolatone over brushed white on the inside would look like?
James Freeman
RV-8 flying
Old 07-30-2008, 01:36 PM
Default The sanding is for flattening
Guys,
The sanding externally is to flatten the internal finish. Just the opposite of "so shinny I can see myself"
By sanding the window rough, it causes all the little surfaces to point different directions, scattering the light.
600 grit was too fine. I may go as big as 200 when I do the canopy.
I might some plxiglass to test various grits.
Steve Brown
Old 05-25-2009, 12:41 AM
Pilottonny Pilottonny is offline
Default Paint the top of the canopy?
Steve,
Did you end up painting the top of the canopy also, as you mentioned in your post? If you did, do you have pictures?
Regards,
Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 05-25-2009, 05:46 AM
tinman tinman is offline
I was considering something similar to this on my canopy. I was concerned that the plexi would not tolerate the Imron (polyurethane) paint since it has solvents in it. Any thoughts about the interaction between the two?
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
Old 05-25-2009, 07:36 AM
Mel's Avatar
Mel Mel is offline
As most of you who have seen my -6 know, I painted the top of my canopy in 1993. It still looks great.
After much research and trial & error, I found that poly-urethane (Jet-Glo in my case) sprayed directly onto the plexi works best. I tried many primers, but never found one that worked.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-25-2009, 10:38 AM
Default Pictures please !
Mel,
Any pictures?
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Sold
Old 05-25-2009, 07:22 PM
Mel's Avatar
Mel Mel is offline
Originally Posted by Pilottonny View Post
Mel,
Any pictures?
Regards, Tonny.
Pictures sent by e-mail.
Old 05-25-2009, 08:27 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Spotty Shade?
Anyone know how to make the spotty car windshield shade that they put between the fold down sun shades and around the edge of the glass to hide the glue line? That would be neat on the back window and overhead to provide some shade but still be see through. A bit like some Enterprise Rental Shuttle windows at airports - and Black Marias or Paddy Wagons for that matter - looks solid from the outside but still see through from the inside.
Jim Sharkey
