Old 07-30-2008, 12:01 AM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default Flaps and dual Infinity grips
What have others been doing to wire the flaps with dual infinity stick grips? I could go with the two relays as suggested by Infinity (if I can find suitable ones here), but I had been looking at the "Flap Positioning System" sold by Vans; except that is designed for a single switch and I am not an electronic genius capable of working out how to use two switches [on the grips].
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 07-30-2008, 01:16 AM
sjjonesnz sjjonesnz is offline
Hey Jeff, I'm not familiar with the infinity grips, but how easy would it be to accidentally deploy the flaps above Vfe with the flap switch on the grip? I'm putting my flap switch on the panel, but in easy reach of the throttle, to avoid exactly that.
Cheers
Steve
Auckland, New Zealand
Flying RV-7QB/ZK-NVS/Aerosport 0320/Dual AF3500s/PMA8000B/GNS430W/SL30/GTX327/TT ADIP II
Old 07-30-2008, 01:59 AM
Default Hi Steve
I considered that but decided I'd just be extra careful
I suppose, if you wished, you could wire an airspeed switch into the circuit...
Jeff Preou
Old 07-30-2008, 06:42 AM
Jon Clements Jon Clements is offline
Default There's a way around that.....
Jeff / Steve -
You can simply run your flaps through a secondary flap switch on the panel before the wiring to the grip switches. The switch on the panel has Flaps On/Flaps off. You put the switch on as part of your take-off and landing checks. When in cruise Flap switch on panel is set to off so you don't accidentally knock it.
I am installing dual infinity grips however still not convinced that I will put the flap switch on the sticks - final decision yet to be made. One thing I am considering is a starter switch through a relay on the infinity grip (with secondary protection switch as described above). This will allow me to start the donk with one hand on grip and the other on the throttle (more relevant to taildraggers).
Cheers
JON
Jon Clements
RV-7 VH-JWC (Flying)
Little River Airfield, Victoria, Australia
ASP IO-360-M1 Hartzell CS Blended Airfoil
Dual GRT HX, GNS 430W, TruTrak DII VSGV, SL40, GTX327, PSE 9000EX, AVMAP EKP-IV.
Approach Fast Stack Integration.
Classic Aero Interior.
Old 07-30-2008, 10:54 PM
Default Clarification
Hi All, maybe I need to clarify my question: I already have the Infinity grips with the momentary toggle switch for the flaps. What I'm after is how to wire them in; I could go with the standard relays as per the Infinity Aerospace schematic on their website, but I wondered if anyone had run through one of the flap positioning system boxes (such as sold by Vans).
Jon: I have starter on my grip and it will be wired to a 'starter enabled' button and annunciator LED on the panel. The rear stick will also have a 'rear stick enabled' switch and annunciator. I don't feel the need to do the same with the flap switch; sure I could perhaps knock it, but the way it is positioned it is only likely to get knocked up rather than down, unless I rest something on top of the stick which I would think unlikely. Ok, never say never and all that, but I don't plan to have a 'flaps enabled' switch as well; I have enough switches already!
Jeff Preou
Old 07-31-2008, 02:54 PM
JonathanCook's Avatar
JonathanCook JonathanCook is offline
Default circuit for flaps
take a look at:
http://www.vansairforce.com/communit...83&postcount=5
and
http://www.vansairforce.com/communit...d.php?p=130383
Jonathan
Celebration, FL 34747 (just SW of Orlando)
RV7
Working on Fuselage
dues paid for 2012
Old 08-02-2008, 04:18 PM
Danny King's Avatar
Danny King Danny King is offline
Jeff,
Don't sweat VFE and accidental flap extension. I have been flying the Doll for over 1000 hours with the flap control on the Infinity stick, and have never accidentally lowered the flaps. Having the flap control on the stick becomes completely natural after just a few hours, and I have really missed having it there when flying other RV-8s.
Danny King
Beautiful Doll 80434 TT 1675 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2020
Old 08-02-2008, 08:54 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I'll second Danny's experience - no problems accidently hitting the switch in the Val, and I really miss having the switch there on other planes - it becomes pretty natural.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-02-2008, 10:10 PM
RatMan RatMan is offline
I'm doing the same thing right now, dual Infinity sticks. I'm using Van's solution. Easy, light and cheap.
Flap control circuit board
I'm using a starter enable switch on the panel for my stick mounted starter button. What type of relay are you using for those?
John Ratliff
N898R
RV-8
Saucier MS
Old 08-03-2008, 01:34 AM
Default Thanks Guys,
I'll either go with the Vans flap board or use two relays as per the Infinity schematic; not sure I understand the schematic though and will try to find someone to explain it to me. I think it is designed so that if front pilot flaps up and the rear flaps down it won't go poo-poo or something! I just don't know why yet! I've also managed to find a local(-ish) guy that has recently set up a business helping builders with their panels and electrical; very timely for me; I've just initiated contact and I'll see where that goes (if anywhere).
Thanks again
Jeff Preou
