Old 07-29-2008, 01:47 PM
Brantel's Avatar
Brantel Brantel is offline
Default Which Carb for an RV-7 and O-360
I have secured a used O-360 with 0 smoh for use on my RV7.
This engine previously had the Airflow Performance FI on it and the prior owner took it off to use it on his new engine. That means I have to source a carb.
Question for the carb experts out there.
Which carb is the best for the bone stock O-360 to prevent the lean climbout issue?
MA4-5 10-3878 or MA4-5 10-4164-1 or ????
What is the best way to find a good carb? Buy a reman? Who has the best price? I do not have a core
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-29-2008, 02:53 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Carb
Brian,
I'm not an expert, but I have drilled my carb on my 0-360 to make it richer.
The 10-4164 is what Vans is shipping on their new 0-360.
If there is a richer one, I'm not aware of it.
Odds are, you will be drilling the main jet anyway to get the fuel flow correct.
Your cowl cooling and your choice of props will determine how much drilling to do.
As for where to get a carb? We purchased a carb from a guy that upgraded to Fuel injection.......so that would be a good place to start looking.
The core value is only about 500.00 so that gives you a bases to shop from.
We actually got a NEW carb for 500 because the seller was a nice guy and offered it to RV guys instead of selling as a core.
So good luck shopping.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 07-31-2008, 01:58 PM
Brantel's Avatar
Can a MA4-5 #10-5193 work on an O-360?
What would be the difference in this and a 10-3878 or 10-4164-1?
Old 07-31-2008, 02:23 PM
N208ET N208ET is offline
Default quality aircraft
I just got mine from David at Quality Aircraft 877-833-6948, $1,550. Lot of money for such a simple yet vital part.
Old 07-31-2008, 04:38 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default MA4-5-10-4164-1
When I ordered my TMX-O360, I was strongly advised to get the MA4-5 10-4164-1 carb. This is richer than the stock carb that Mattituck supplies.
The advise came from my brother who has over 800 hrs on his RV-7A with an O360. He switched from the leaner carb to this one.
Maybe he'll add some detail if he reads this thread when he gets back from OSH.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 07-31-2008, 07:03 PM
Brantel's Avatar
It is my understanding that all it takes to make a 10-3878 a 10-4164-1 is a drill bit and bore out the main jet. Just what I have seen here so I may be incorrect.
Old 08-01-2008, 12:49 AM
Doug Rodrigues Doug Rodrigues is offline
My parts manual shows three carbs for the O-360, not including the side draft carb:.
10-3878 ... A1A, A1AD, A1D, A1Ld, A2A, A2F, A3A, A3AD, A4A, A4M, A5AD
10-4164-1.... A1A, A1D, A2A, A2D, A2F, A3A, A4A
10-5034 ...A1F6, A1F6D, A2F
