Old 07-29-2008, 09:27 AM
Webb's Avatar
Webb Webb is offline
Default Access door in wheel fairings
I looked but didn't find anything about an access door in the wheel fairings for routine pressure checks of the tires.
With all the discussion about tire pressure on the nose wheel to prevent an accident, I began thinking that I would like to have an easy way to check pressures on all tires without pulling the the wheel pants off. Down side is you don't visually inspect the assembly each time but easy pressure check would be the upside.
Since I'm close to finishing the wheel fairings, now is the time.
I had 2 thoughts.
#1 - It would be very easy to cut a small door, hinge and back frame it for support with a latch / camlock fastner / placenut & screw.
#2 - Cut a 1" hole like the one used in the front fairing for the tow bar that would allow you to put a gauge/filler on the stem. Faster and easier than option #1 but tight quarters to get the valve stem screw top on/off.
Good ideal - bad ideal? Has anybody done either?
Webb Willmott
Jackson, MS
N32WW
Old 07-29-2008, 09:35 AM
664781 664781 is offline
Webb,
I did #2 and take the stem cap off with a 1/4 drive socket. No problem...
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 07-29-2008, 09:45 AM
erich weaver's Avatar
Check out http://www.aircraftextras.com/ - scroll down until you find "valve extension"
works for me
erich
Old 07-29-2008, 09:51 AM
Webb's Avatar
Default Hole location
Originally Posted by 664781 View Post
Webb,
Where did you put the hole?
I also noticed on Aircraftspruce, Camloc has a 1" plate cover that is spring loaded:
http://www.aircraftspruce.com/catalo...ccessdoors.php)
Not sure I want to spend 75 bucks for those if not really needed but look nice. Could always add later since the hole is a 1 incher.
Webb Willmott
Jackson, MS
N32WW
Old 07-29-2008, 10:03 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Or....
I didn't go with the access holes because I was to lazy to figure out where they would go. It takes me about 30 seconds to get the front half of the wheel pant off - about as much time as I used to spend hunting for the tire valve through the holes on my old Grumman. Using Michelin Air Stops, I only have to check/add air about once every three months or so, and I generally find that I have the front halves off to check tire or brake wear in that time anyway.
It is certainly not as trick as having access doors/holes, but I haven't found that I miss them.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-29-2008, 11:21 AM
John Clark's Avatar
John Clark John Clark is offline
Default Tire and brake inspection...
...is just as important as tire pressure. A couple of minutes spent once a month can avoid a lot of problems.
John Clark
RV8 N18U "Sunshine"
KSBA
Old 07-29-2008, 11:37 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Webb View Post
I looked but didn't find anything about an access door in the wheel fairings for routine pressure checks of the tires......
I installed flush mounted spring loaded Camloc type wheel pant access covers. They are very easy to install using two AD4 rivets and a retrofit can be done anytime. The photo in the link shows INSIDE detail of a cover.
Check around for competitive pricing. A few years ago, I bought a number of them as "new surplus" from a vendor at the AirVenture Flymart for $5 each.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 07-29-2008, 11:44 AM
Geoff
Posts: n/a
Default No access doors
Maybe I'm just extremely lucky, but I've been flying since last September and in 70 hours I've never had to add any air. They've dropped maybe 1-2 psi in 10 months. I'm using whatever tires/tubes Vans supplied with the kit.
Old 07-29-2008, 08:36 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I put the 1" hole where the valve is in the "six o:clock" down position. I marked the tire with a red line to find it easy. Also use a valve extention I bought from NAPA.
L.Adamson -- RV6A
Old 07-30-2008, 12:25 AM
Pirkka Pirkka is offline
I did looked as well...
http://www.vansairforce.com/communit...ad.php?t=17804
http://www.vansairforce.com/communit...ead.php?t=2966
http://www.vansairforce.com/communit...ad.php?t=27685
Hope these helps!
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
