Old 07-29-2008, 04:14 AM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Repair to Cowl Heat Damage
My 450 hr 7 year old -8 came complete with some delaminations of the inside surface of the lower cowling. I just changed to a AWI 4-into-1 exhaust and want to reapir these areas and then protect the lower cowl from heat. I've read some other threads on the forum about reflective tape, etc., but I'm more concerned about the F/G repair.
I didn't build this plane, but I have a lot of experience with Epoxy and glass, having built most of the airframe on a Long-EZ. (That's another story for another time) I started repairing the cowl last night by cutting away the bubbled up fabric and then using a sanding disk to feather back the edges to where the skin is still bonded to the honey comb core.
I then lightly sanded the entire interior surface and wiped it down with thinner, which I will follow up with alcohol. This morning I mixed up some Aeropoxy and dabbed it in various places to test compatibility with the existing skin and core.
My question has to do with the new layup over the core. I think core usually is laminated with prepreg and vacuum bagged and I won't be able to do that here. I think they also use some thickened epoxy rolled on the core before the skin is put into place.
Can anyone offer some suggestions for good technique dealing with the honey comb core?
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 07-29-2008, 08:00 AM
DanH's Avatar
DanH DanH is online now
<<I think they also use some thickened epoxy rolled on the core before the skin is put into place. Can anyone offer some suggestions for good technique dealing with the honey comb core?>>
I've not seen epoxy rolled on honeycomb prior to prepreg. Maybe sometimes, can't be sure. It is common to fill the honeycomb in the area of attachment hard points.
Why not treat it like filling foam surface on the EZ? Wipe dry micro in the comb and do the layups. Very little weight, and it would really stiffen up the honeycomb if it has suffered any heat damage.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-29-2008, 01:50 PM
AMURRAY's Avatar
AMURRAY AMURRAY is offline
Default AC 43.13-1B
Has good instructions on how to repair honeycomb core, Page 3-2 and 3-3. Good enough for the Feds good enough for me.
RV6 built and flying
Bearhawk Patrol plans purchased
Old 07-29-2008, 06:45 PM
Bubblehead's Avatar
DanH - good idea on filling the honeycomb. I especially like the idea of stiffening up the areas that may have some heat damage.
I think the thickened epoxy was used so fillets were formed around the thin walls of the honeycomb, but that would require the layup to be done upside down. Fabric/epoxy first, then honeycomb. In this case I have to do the layup with fabic on top of the honeycomb.
AMURRAY - I'll check AC 43.13 Great suggestion.
Old 08-06-2008, 10:06 AM
Bubblehead's Avatar
The repair went well and after two flights everything is still in good shape. More info on how I repaired the cowling and the heat barrier I used can be found in this thread http://www.vansairforce.com/communit...t=31370&page=4
I've posted some pictures of everything here: http://tangodelta.smugmug.com/galler...48742355_RDjHa
