Need clearance.
That hose is indirectly attached to the engine which shakes considerably. The nose gear does not move (or shouldn't). If the hose is touching the nose gear, it will wear quickly. You should have "some" clearance. I would recommend at least 1/4" to 1/2".
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
