Old 07-27-2008, 10:39 PM
kevinh's Avatar
kevinh kevinh is offline
Question Loops all day long - CHT temps?
Hi ya'll,
I thought I did a reasonable job on engine cooling, baffles etc but now I want to check...
With my O360-A1A - should I be able to do one loop after another without pausing to let CHTs go down? My peak CHT hits 420 after about three loops, and that's when my EIS warns and I back off.
Should I go back and work on my baffles more? The last time I had the cowl off I didn't notice any obvious leaks...
Oil temps stay fine.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 07-28-2008, 06:30 AM
AlexPeterson's Avatar
It's all about power vs airspeed. Since loops are mostly at airspeeds less than that which you would fly at for the same power settings, you can expect less cooling. I've found that with any vertical to speak of, I'll see temps creep up. Never tried three loops in a row.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 07-28-2008, 07:32 AM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default You might consider drilling your carb jet.
Kevin,
If you have the 10-3878 carb, it may be a little lean.
This has been discussed before.
http://www.vansairforce.com/communit...t=drilling+jet
There are some other threads about it also.
I haven't even flown yet and drilled mine to .125
Just a thought.
Mark
Originally Posted by kevinh View Post
Hi ya'll,
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 07-28-2008, 07:59 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Data Point
Hey Kevin, here is a sample of "1" for you....I usually go up for acro, set 75% power at 4,000', lean until the EGT's knee over, and then just fly - haven't gotten any alarms for CHT (limits set at 420), and hadn't bothered to look. I routinely do cloverleafs, essentially 4 loops in a row. The only time I start getting temperature problems are when I do slow flight - then I get oil temp alarms first.
TMX-O-360-A1A, Carbed, stock baffles
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
