My Mooney didn't have drains either, and it is set up the same way as my -7. Both the pitot and static openings are already the lowest point in the system. The pitot will be covered when not in use as well. Actually, thinking about it, the pitot probably did have a drain on it, but not one with some kind of manual release. The AOA system I installed does provide a spring drain to check for water though, it is a tiny (.040)hole on the upper surface of the wing
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
