Originally Posted by Doug Eves
In reviewing the NOTAM I'm left with a question that doesn't seem to be adressed. There are two stream's of traffic at 1800'/90kt and 2300'/135kt navagating the same route inbound. I'm trying to visulize at some point the higher and faster stream decending into the lower and slower stream. Is this what happens or do they land the top stream long and keep them separated or??? I flew once before years ago as a passenger but never noticed this. It would seem that the preferable entrance would be the higher/faster one?
This is what the controllers do.
Make sure you know the NOTAM absolutely cold, so you know what the pattern is going to be.
The controllers will identify you ("Blue RV, rock your wings") and when you respond they will give you instructions ("Turn left base for 36 L now, follow the cherokee in front of you, land on the orange dot.")
Don't talk on the radio, it just gums things up. Watch for other people that aren't paying attention.
Most important, remember to fly the airplane. A couple of people seem to forget this most years.
If you've never been before, try to find one of the live audio streams on the internet and listen--I think it will be a big help.
