For those of you who have put the Grove wheel on the nose, did you notice if the bead of the tire fit better than on the Matco? The beads on the Matco don't seat even up to 80 psi (put the rim in the vise...). They appeared to seat, but upon deflation, it could be seen that there is about an 1/8" gap. That is probably why it is such a bugger to get the beads unstuck when changing tires or tubes.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
