Old 07-23-2008, 09:30 PM
celstar's Avatar
celstar celstar is offline
Default fuel pressure is 0
Did my run up today and seen 0 fuel pressure at 1800 rpm! I have a Aerosport O 360 Carb not injected. The plane seems to run o.k at this rpm however when i bring it down to 800-900 it seems to miss a lttle witch i believe to be fuel related. The motor does not totaly stop it still keeps runing and when i turn on the fuel pump the pressure goes up to around 5-6 pounds. I turn off the boost pump and it slowly comes down to zero. Any ideas would be great, Im thinking mechanical fuel pump but dont know why this would be out at only 90 hours tt?
Old 07-23-2008, 09:34 PM
asav8tor asav8tor is offline
possible, infant mortality.
Old 07-23-2008, 10:11 PM
PCHunt PCHunt is offline
Could be sucking air in the fuel system at a bad connection.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 07-23-2008, 10:17 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Default What?
Just curious how it could even run with 0 fuel pressure. My guess is that your fuel-pressure indicator is wrong.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 07-23-2008, 10:25 PM
Norman CYYJ Norman CYYJ is offline
It is not uncommon to see fuel pressures vary and go down to zero. You may be flying along or on climb out and the fuel pressure drops to zero with the engine running just fine. I spoke to Bart about this several planes ago and said it was a common occurence. He had no real answer for it. I did notice that when the boost pump was turned on sometimes the pressure would increase sometimes by a pound or two. But in your case you say the pressure is dropping with the boost pump on. Check your fuel pressure with the engine off and the boost pump on and check for leaks. Check both tanks, maybe a leak on the input side causing air to enter the system but I doubt it. Srange.
Old 07-24-2008, 05:50 AM
celstar's Avatar
The pressure goes up and stays up when the boost pump is on, when i turn off thr boost pump it will slowly go back down to zero with the engine running.
Old 07-24-2008, 06:27 AM
Geico266's Avatar
Geico266 Geico266 is offline
Sounds like your mechanical pump is dead or dying. There may be just enough fuel flow (that doesn't registered on the gage) to keep the engine running. Because the boost pump get the pressure readings up, I'd replace the mechanical pump right now.
Have you flown it like this? What was the result?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 07-24-2008, 06:30 AM
Doug's Avatar
Doug Doug is offline
Please advise the source and type of fuel pressure transducer you have?
Old 07-24-2008, 06:47 AM
videobobk's Avatar
videobobk videobobk is offline
I know this is VERY basic, but you are sure the pressure line is downstream of the mechanical FP and not off the inlet? Also bleed any air out of the line to the transducer. Infant mortality would be probable if the plumbing is right.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 07-24-2008, 07:56 AM
celstar's Avatar
I have not flown it like this, I do not want to untill i see somthing for fuel pressure with out the boost pump on.
