Old 07-23-2008, 07:07 PM
avi8tor50 avi8tor50 is offline
Default Sealing Foam Inserts
Hi all-
Have fabricated blue foam inserts to close off the cowl ramps on the sides. Was wondering what people use to seal the foam? Straigt epoxy? Mixed with microballoons or flox?
All help appreciated. Thanks.
Peter K
9A
Old 07-23-2008, 08:29 PM
kevinh's Avatar
kevinh kevinh is offline
Originally Posted by avi8tor50 View Post
Hi all-
Peter K
9A
I didn't bother with foam to seal off the cowl ramps. I just layed up two layers of fiberglass to make a sheet and laid that sheet onto the ramp and cowl. After the glass dried it looked like it was meant to be that way. Been fine for 200 hrs - super low effort.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 07-23-2008, 08:34 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default 2 layers of glass
I used the tan foam, for a the same purpose. Sanded to fit the hole and secured with epoxy and micro filler. After curing, I laid in 2 layers of 8 oz cloth and feathered in for a nice look.
The foam gives the glass something to lay on making the job a little easier.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 07-23-2008, 09:07 PM
Webb's Avatar
Webb Webb is offline
Default Foarm for support
I used foam for support. Cut to fit and set in place. A dab of superglue to keep if from shifting and then 2 layers of cloth. A wee bit (ok a lot) of sanding and it was done.
Webb Willmott
Jackson, MS
N32WW
Old 07-23-2008, 10:35 PM
SportAvServ SportAvServ is offline
Thumbs up Ramp side fillers
Please share pictures of your handy work.
RT
Old 07-24-2008, 06:49 AM
decathlon737's Avatar
decathlon737 decathlon737 is offline
Default Ramp Closures
I posted photos in the 9th reply on this thread.
http://www.vansairforce.com/communit...ad.php?t=31895
Bill Woods
RV8 sold 180 hrs. of pure joy
(Nov 2018) Bought 7A Tip up
project, converting to tailwheel
slider (just because)
Thunderbolt YIO390
Hartzell BA
Steinair Panel (WOW)
