Old 07-23-2008, 06:30 PM
flickroll's Avatar
flickroll flickroll is offline
Default Yet Another Newbie Question (RV-8 Vert. Stab.)
I just finished riveting the VS rear spar together, and the ribs to the front spar. I have noted in a few builders logs some builders make provisions to run a wire to the top of the vertical stab. What would this be for; I can't figure why you'd want a wire here. Running lights on my airplane will be on the fiberglass rudder fairing. What am I missing? I'm about to close up the stab so it's time to drill wire holes or forever hold my peace....... Thanks
Jim Shannon
RV8 N52VV
Old 07-23-2008, 06:34 PM
JHines JHines is offline
Default VOR antenna
The top of the VS is a traditional place for VOR antennas, although I think a whole lot of RV builders use the ones that are buried in the wingtips.
Jonathan Hines
Charlotte, NC
Old 07-23-2008, 07:01 PM
osxuser's Avatar
osxuser osxuser is offline
I've seen a lot of rvs put them at the bottom of the fuselage right under the HS.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 07-23-2008, 07:07 PM
mannanj's Avatar
mannanj mannanj is offline
Default Wire
I installed a "lipstick" video camera in the vert. stab. fiberglass tip of my RV-8. Used #22 aircraft wire for power and a shielded #22 for the video signal.
The video signal can then be recorded on any number recording devices.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 07-23-2008, 08:27 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I've still got a string running up through a conduit there in case I ever want to pull a wire for a video camera.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
