Old 07-23-2008, 06:23 AM
flickroll's Avatar
flickroll flickroll is offline
Default Avery Dimple Dies Leaving Marks
I am using Avery spring back dimple dies on my RV8 project. They produce a circle of very fine circular scratches around the dimple. They are not very deep and will come out with light strokes with a purple scotchbrite pad. However, if I decide to polish the airplane rather than paint (doubtful, but a possibility) it would require a lot of work to get them out and then re-polish. I think they would disappear during surface prep and painting if I decide to paint the airplane. Nevertheless I am not happy with the way they look and would appreciate comments and suggestions. I would post a picture but am not sure how to do so. Thanks
Jim Shannon
Old 07-23-2008, 06:29 AM
Pirkka Pirkka is offline
Like this?
http://www.vansairforce.com/communit...t=dimple+marks
I'm sure they won't need much more extra to polish out if going to polish whole plane... do you have any idea how much it takes to polish the plane?
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 07-23-2008, 06:34 AM
flickroll's Avatar
Exactly like those. The thread indicates they are OK, but I still don't like them. Is there any way to dimple and not have them appear? Maybe a dimple set from a different manufacturer? Or just keep on trucking the way I am going?
Jim Shannon
Old 07-23-2008, 06:35 AM
Allen231ah's Avatar
Allen231ah Allen231ah is offline
Tool marks are common when forming metal . I deal with it in the furniture manufacturing business every day . You are forming soft metal with a hard tool . I don't think anything is wrong with the tooling. You may want to leave the protective plastic coating on the metal while forming that will help.
"Miss-Jessi"
RV-8 N231AH
Allen Holcombe VAF962
Old 07-23-2008, 07:24 AM
Geico266's Avatar
Geico266 Geico266 is offline
Primer coat of paint will cover it right up.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 07-23-2008, 07:31 AM
Sid Lambert Sid Lambert is offline
I don't think this is a good idea for dimpling. After drilling, that coating will hold the metal shavings/chips. If you dimple it with trash attached it will just embed the trash and potentially cause cracking later.
My vote is don't worry about those small marks.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 07-23-2008, 08:31 AM
BrentHumphreys BrentHumphreys is offline
I am pretty new to this, but here is what I have learned.
Those are witness marks, and a sign that you have done a complete dimple. Remember the alclad is very easy to scratch, but it is necessary that you allow the die to contact the material completely.
The scratches will buff out in the polishing process, and are more desirable than having your rivets sit proud of the skin.
Brent Humphreys
PPSEL
RV-10 (Starting Empennage )
Status: Elevators
N411BE Reserved
Build Log
Old 07-23-2008, 12:24 PM
penguin penguin is offline
You did get the regular diameter spring back dimple dies - part no 3/32 DDS? Although they are more than twice the price of the cheap version it is worth it.
Pete
Old 07-23-2008, 12:36 PM
jmartinez443 jmartinez443 is offline
Jim Shannon
The farther you get along on your plane the less you are going to care about those dimple marks. What you are experiencing is new builder perfection syndrome. Don't worry, it goes away. Keep on trucking.
Jorge Martinez
QB 8A Fuse. Just battled the ^%&@ing gear weldments. Now I can move on.
http://www.rv8alog.com
Old 07-23-2008, 12:39 PM
osxuser's Avatar
osxuser osxuser is offline
They polish out just fine, I've done it plenty. Some fine grit Nuvite did it for me.
RV4 wing in Jig @ KPOC
RV7 emp built
