Old 07-22-2008, 11:52 PM
rchaney rchaney is offline
Default EI engine probes for Dynon or other: Possible?
If I were to upgrade a panel with Electronic International Gauges to a Dynon or other "glass" monitor, would it be possible to use the current, in-place probes with the new monitor?
Are probes interchangable... at all?
Ralph
Old 07-23-2008, 10:30 AM
Mathew Sharp's Avatar
Mathew Sharp Mathew Sharp is offline
Ralph
You could probably use things like flow transducers but psi transducers wont work.
Temp probes are a question mark. If Dynon has the ability to take a Type K ungrounded probe then it should work.
Matt
Electronics International Inc.
Sales/Support
63296 Powell Butte Hwy
Bend, OR 97701
www.buy-ei.com
support@buy-ei.com
877-318-6060 Ext 113
