Old 07-22-2008, 09:50 PM
Default Gaffer's Tape Temporary Speed Mod
From another thread I was informed that Gaffer's tape would be best for a temporary speed mod to close the bolt access openings in the rudder and elevator of our RV-6A. I completed the installation today after a lengthy "cut, try and replace" process. It truly is a learning experience. I test flew it today at 6,000 ft density altitude per the www.us-airrace.org handicap procedure and inserted the three speeds and tracks into the National Test Pilot School spread sheet. The resulting speed was 182.6 kts which is a 1.3 kt increase over the previous high speed configuration. Inspection of the tape after the flight showed it to be the same as it was before starting the engine - thanks for the recommendations.
Bob Axsom
Old 07-23-2008, 06:19 AM
IBPJ IBPJ is offline
Bob can you post some pics?
Thanks PJ
Old 07-23-2008, 09:52 AM
Default Sorry Doesn't Work Anymore
I have the photos but the old imageshack method doesn't work for me any more. I tried around 5 times.
Bob Axsom
Old 07-23-2008, 10:36 AM
Default I sent you a private message
I can't send photos that way either but if you or anyone else has an interest in seeing the photos, give me your e-mail address and I will try to send them to you.
Bob Axsom
Old 07-23-2008, 10:44 AM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
Send them to me Bob. I'll put them on one of my image servers and then post links.
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 07-23-2008, 11:09 AM
Bill Dicus Bill Dicus is offline
Default Tape photos
Thanks Bob: I'd appreciate seeing those also if you have time and opportunity. E mail is dicusd37@aol.com. Bill
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 07-23-2008, 01:09 PM
GrayHawk's Avatar
Here are Bob's photos of the gaffers tape mod.
GrayHawk
Old 07-23-2008, 03:32 PM
GrayHawk's Avatar
My apologies if anyone tried to access or view the photos a short while ago & could not. Took a lightning hit to the transformer on my power pole and it took longer than my backup supply lasted to repair it. Need to get larger backup supply I guess.
GrayHawk
