Originally Posted by Oldgeezer
I initally thought that I would just buy an oversized ct bolt and found the price really shot up.
Oldgeezer
RV9A
Hi from Europe, could I please pick your brains re suppliers for the oversized close tolerance bolt, specifically a .3115 CT bolt.
I have had the very same problem with the rear wing spar attach bolts - reamed them out to .3115 using Avery 5/16" undersize reamer stupidly assuming that they were .3125 (5/16") and then finding they are .3110 and loose in the hole !
(There have also been other posts on this point - I feel a warning from Vans on the plans would help with this issue as they say it is not desirable to have movement for this bolt location - glad I didn't use a 5/16" drill.)
GAHco is one supplier but I am having a problem email'ing them as an International customer - also I am not sure that they have a .3115 CT bolt. Also looked at A/c Spruce - no luck.
