Powder Coat, etc.
Powder Coat:
Option 1: Van's sells a small bottle of touch-up paint for the powder coat.
Option 2: You can scuff up the powder coat with a Scotch-brite pad, clean with MEK or Acetone, and then prime/paint over the powder coat. A quick search on this website will give you a range of options for primer and paint combinations.
Countersink and Dimple:
Make a sample/template in scrap aluminum of the dimple. Use another piece of scrap and work with your countersink until you get the depth right and use that as a reference template. I made a template (all in a small circle of aluminum) for #40, #30, size 6 and size 8 dimples and a matching countersink template in some thicker stock. Make it once and keep it in the toolbox. Once you get a good fit you can use the template to dial in your countersink. Trust me, you'll use this a lot.
I'm doing a standard kit so can't help with that one.
Good luck,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
