Old 07-21-2008, 07:58 PM
rfinch rfinch is offline
Default How to mount the Ray Allen trim servo
Minor question. Need to mount the Ray Allen elevator trim tab servo to the EET-602B Z brackets; Vans plans (Dwg 4) say to use hardware supplied with the servo, but I don't think I got that. And Ray Allen's instructions don't specify. Bolts would work of course, and rivets seem doubtful given the plastic servo case. I will call Ray Allen tomorrow but wanted to check the VAF Source also.
Ralph Finch
Davis, N. California
RV-9A QB Log
Old 07-22-2008, 09:21 AM
danielhv's Avatar
danielhv danielhv is offline
The servo should have had some brackets in the box... Z shaped brackets to mount the servo to the inspection plate. The brackets are riveted to the cover after you drill the holes. Make sure that you TEST FIT and check alignment before drilling, the measurements on the plans are off by about an 1/8th of an inch. If you do not catch this before you drill the holes, you'll likely end up having to cut the hole that the servo arm passes though bigger.
Old 07-22-2008, 09:30 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Screws.
In the 10, I seem to remember I had to drill out the holes just a tiny bit to fit the screws called out---------#6??
Nut plates on the bottom of the bracket, but again, this was a 10 trim system, I am pretty sure you will have room for nut plates also, may have to use single wing units.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-22-2008, 09:56 AM
airguy's Avatar
airguy airguy is offline
In my case, there were two Z-brackets included in the empennage parts I got from Vans - dunno if this is standard or a new change?
http://websites.expercraft.com/airgu...y&log_id=25608
Old 07-22-2008, 10:07 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Screws.....I am pretty sure you will have room for nut plates also, may have to use single wing units.
Good luck.
That is more or less what I did. Though fiber nuts would work just as well, using 4 single leg #6 nutplates on the upper flange of the Z brackets, I attached the servo to the two brackets. The servo/bracket assembly was then located over the cover. When proper clearance was assured, I drilled for and installed rivets through the cover and the lower flange of the Z brackets.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 07-22-2008, 12:14 PM
Just called Ray Allen, they recommend 6-32 screws to attach to servo to the Z brackets; I'll consider nutplates there. Then rivets to attach the brackets to the cover plate. Thanks guys for your replies too!
Ralph Finch
RV-9A QB Log
