430W antennas ... Questions ... What did you do?
I'm installing a Garmin 430W. I'm planning to install the Bob Archer wingtip antenna. I have the strobe light power supplies mounted in the wingtips.
1. Does the Archer antenna provide glideslope?
2. Will the strobe light power supplies affect the antenna performance?
3. How will do the marker beacon antennas made from a piece of coax cable work?
4. If you had to do it again would you install the wingtip or external VOR antenna?
5. It looks cheaper to install two Archer antennas-one in each wingtip-than buy the Comat 507 splitter.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Reason: Need more responses.
