07-19-2008, 04:33 PM
Corrosion protection for "inside" steel parts
What do people use for corrosion protection on the "inside" of the powder coated parts? I'm thinking of parts like the aileron torque tube assemblies, which are powder coated everywhere except inside the tube. Using the same method as the aluminum parts? Something different? Nothing at all? I'm planning on using the same rattle can self-etching primer I've been using all along, but am curious what others are doing.
Thanks...
Rob
Rob Kochman
RV-10, Flying as of March 2011 ( blog)
Paine Field (KPAE)
EAA Chapter 1440
07-19-2008, 05:47 PM
The only way something can rust if moisture gets in there. I used sealant at each of the ends to completely seal the tubes and block out any moisture from getting in.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
07-19-2008, 06:19 PM
The traditional method for steel tubimg is to pour in some boiled linseed oil. Rotate the part around to get an even coat, then let the excess drain out. You could also pour in some primer/rust preventative. Sealing the openings after doing this would be the ideal way treat the parts.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
07-20-2008, 10:28 PM
Sounds great... I'll use the boiled linseed oil and seal those that I can. Thanks for the help.
-Rob
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
07-21-2008, 12:48 AM
Be vary carefull using boiled linseed oil. Rags and paper towels wet with linseed oil will self combust. Be very carefull how you store and dispose of them.
Mike Sumner
Castaic, Ca
07-21-2008, 06:28 AM
The worse for combustion
This man is so right. Test for spontaneous combustion showed that linseed oil was hands above other oils.
I almost lost a car due to castor oil which was in RC model fuel. A rag that had fuel on it was in the my start box started smoking while I was driving back from flying. When I pulled over and threw it out, it burst into flames.
Webb Willmott
Jackson, MS
N32WW
07-21-2008, 11:23 AM
WHOA! That's crazy!
07-22-2008, 12:32 AM
I would rather consider priming those from inside. Doesn't oiling make them much harder to seal from ends?
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
07-22-2008, 06:56 PM
I let the oil drain out for a hour or so then attached the end fittings before the oil had cured. Regular primer may or may not be better, but oil is a time-tested method.
Jeff Rosson
Repeat Offender
VAF Number: 1170
