Old 07-19-2008, 03:50 PM
BrentHumphreys BrentHumphreys is offline
Default Help with Damaged VS Spar
I just got the RV-10 Emp kit yesterday, and as I was unpacking, and doing the inventory, I noticed the VS-1003 has some damage.
I am curious what the group here thinks about a possible repair. Looks like I should be able to straighten the main part of the part with a block of wood, then straighten the rest with a hand seamer.
I am concerned about the crease along the line of holes. Any advice would be very appreciated.
Bigger photos here
Brent Humphreys
PPSEL
RV-10 (Starting Empennage )
Status: Elevators
N411BE Reserved
Build Log
Old 07-19-2008, 03:56 PM
WilburD2 WilburD2 is offline
Default Why fix it?
Damaged in shipment? sounds like either Vans or the shipping company owes you a new one free of charge..
Bill S.
A+P, RV Dreamer + Schemer
RV-9 preplans in hand
Pmerems's Avatar
Pmerems Pmerems is offline
Default Don't use it-replace
Just call Van's up and tell them it is damaged. They will send you a new one (free of charge).
Sometimes stuff happens.
Paul
Old 07-19-2008, 04:00 PM
Yeah, I plan on it. I was hoping to get started on it this weekend. That is the first part of the kit.
I suppose I could do some work on the rudder.
Brent Humphreys
PPSEL
Status: Elevators
N411BE Reserved
Build Log
Old 07-19-2008, 04:12 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Battery tray or trim assembly is another thing you can do while you wait.
Both lots easier than the vert stab.
Or, just start de-burring parts so that when the new spar comes in, you have all the rest of the stab pieces ready
You could even use the damaged spar to mock up the assembly, drill/dimple etc, and then when the replacement spar comes in, just use it for the actual final sequence.
Or, just have a cold one and read the plans.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-19-2008, 04:15 PM
I have been kicking back and catching up with VAF after being gone all week (thanks again for the RSS Feed)
Brent Humphreys
PPSEL
Status: Elevators
N411BE Reserved
Build Log
Old 07-19-2008, 04:32 PM
AltonD's Avatar
AltonD AltonD is offline
Thread drift, Sorry.
What's an RSS Feed?
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 07-19-2008, 04:41 PM
Originally Posted by AltonD View Post
What's an RSS Feed?
It stands for really simple syndication. News sites, blogs, etc use it as a way for you to pull content from many sources to a "Fead Reader" like Google reader, or Outlook 2007, etc.
Each new topic on VAF creates a new entry in the feed, I can skim that list and click the link to get to the topics that are interesting to me.
For me, this is easier than going to different sites and checking for new messages.
I can also use it to follow many builders logs, etc.
Hope that helps
Brent Humphreys
PPSEL
Status: Elevators
N411BE Reserved
Build Log
