Same here, but I usually use lacquer thinner instead of dishwashing detergent to remove oils and clean the surface before shooting primer, personal preference.
MEK is about the hottest solvent you'll have on hand, that's the big sledgehammer in the solvent world. Backing down from there would be lacquer thinner, acetone, alcohol.
