My wire bundle was very large - a lot of wire plus 3 coax cables. I curved mine to left just above the brake lines, then up the firewall stiffner.
I had to cut off most of the left flange of the vertical part of the cover, below the heater "shelf" to get clearance. I also had to modify the bottom of the "door" that the cables pass through to get enough clearance to make the transition from horizontal along the floor to vertical.
After I did mine, I saw a picture were some one split the bundle - some wires went left and some went right. If I were doing it again, I would at least try that approach, rather then one big bundle.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
