Old 07-17-2008, 09:59 PM
Rockyjs Rockyjs is offline
Default Phase I flying in Class C
I'm coordinating with my DAR on a test flying area. Today he told me no class "C" airspace. I've checked but can't find anything on this. My field is under a lateral limit of class "C" and my plan for the first flight is to enter a Delta pattern above the field that would be in the class C airspace. Am I missing something?
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
Old 07-17-2008, 10:20 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
I'm looking at my year 2000 Operating Limitations, and one line item in the General Limitations states;
"Except for takeoff and landings, this aircraft shall not be operated over densely populated areas or in congested airways."
Let's not even debate this one...since I fly into the Los Angeles basin most every weekend
A Phase I limitations states where I can fly (25 mile radius of Mojave airport) excluding densely populated areas, congested airways or restricted areas.
I would think the DAR is trying to say, "Depart the Class C airspace, don't hang around..." I would consider Class C airspace most likely near densely populated areas. Be sure you get this spelled out (to your advantage). Good luck Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 07-17-2008, 10:26 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Tucson (KTUS)
Many planes in Phase I testing use Tucson International in the center of a Class C ...however, there are many clear approaches to the field not over "congested" areas.
Class C alone should not be a deterrent.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-17-2008, 10:41 PM
Jim P's Avatar
Jim P Jim P is offline
And we have a Class C for Whidbey Island NAS here up in the Northwest. Pretty desolate area up there. I'm assuming they just need the airspace for the Navy fast-movers.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 07-18-2008, 06:10 AM
Mel's Avatar
Mel Mel is offline
Default No Class A or B for phase I.
There should be no problem with Class C per sey. Again, like others have said, "no congested airways". What Paul says is probably what your DAR has in mind.
Class A and B airspace are definitely out.
And keep in mind that the DAR can further restrict you from any airspace he/she thinks is not compatible.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-18-2008, 07:18 AM
Sam Buchanan's Avatar
been here awhile
DCU (Pryor Regional, Decatur AL) is under the HSV (Huntsville, AL) class C and has been the site of several first RV flights. We usually call the tower at HSV, tell them we will be making a first flight, and have always been cleared into class C to orbit over DCU at whatever altitude we want, usually 4000'.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 07-18-2008, 07:38 AM
Thanks everyone. That's pretty much what I figured. I've already talked with Pensacola approach and they have no problems with my initial flight planning. I'll make sure that the DAR and I discuss this. My test area (proposed) keeps me clear of most of the class C, and doesn't contain any densely populated areas.
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
