Old 07-17-2008, 03:03 PM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default Primer/paint the canopy slides
May be a dumb question, but I live in the Waikato in NZ which is very wet. Therefore I am priming everything with two-pot epoxy (PPG DP40) on my RV-8. I'm at the point where I am working on the canopy and just wondered whether I should primer the slides or whether doing so would cause problems with the, er, sliding? I ask because I see lots of photos of painted planes with bare aluminium slides. What do you think?
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 07-17-2008, 05:59 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Jeff-
All of the RV's that I've seen with painted rails (especially the side ones) are really chipped up and ugly from the action of the rollers. I have seen a couple of builders anodize them and they looked much better. In general, the vast majority that I've seen are left bare aluminum. I doubt the weather will do much to them, especially since they are, I think, very corrision-resistant 6061. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 07-17-2008, 08:24 PM
C-J C-J is offline
Default Slide Rail
Jeff,
Buff them with a cotton wheel and buffing rough then just use car or airplane polish on them from time to time. They will look great and be protected.
Old 07-17-2008, 10:01 PM
Default Polished on anodized
...tough call !! I do like the anodized option though. The rails may be 6061, but the cap strip on the center rail is 2024-T3 .063" so would need protection just the same as the rest of the plane. At least I'm getting the hint; no paint. Gotcha . Thanks guys.
Jeff Preou
Old 07-17-2008, 10:48 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Primer...what's that...???
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 07-18-2008, 02:59 AM
Default Well...
...you probably don't even know what water is in Texas, huh?
Jeff Preou
Old 07-18-2008, 04:53 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Anodize option
Jeff,
On my -6A, I took many small canopy parts including the side rails, canopy handle and latch, the "dog house," and the center track rail to an anodizer. The price was under $100 and it didn't matter if it was just one part or many parts, the price was driven on how many items could be placed into a dipping basket at one time. Available in many colors including clear, if I had it to do over again I would have had the side rails anodized black and some in clear...but then the price would have been double what I paid.
Surface prep is important. Small scratches not blended out will show right through the anodize.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Pilottonny Pilottonny is offline
Default Black anodize!
These rails are anodized, but after cutting to length, drilling, etc. you probably want to have them anodized again.
I will get them black-anodized, that way they will go better with my gray interior and don't stick out so much when the canopy is open.
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 07-18-2008, 02:02 PM
Default Blue anodized
Hi Guys,
thanks for those reponses. I'm going to go with blue anodize and they will go nicely with my intended paint scheme, interior and blue anodized modified rudder pedals. I'm going to phone the anodizing guy after the weekend and find out how big his tank is.
Jeff Preou
Old 03-30-2012, 09:40 AM
brad walton brad walton is offline
Default Primed and painted
Hello AntiGravity--I primed my RV-8 canopy side and rear slides with DuPont Variprime, Corlar epoxy primer and finshed with Imron. I only have a bout 75 hours so far, but no chips and no binding. No problems, works great and protected from the elements. My opinion is it looks better than bare also.
