Old 07-16-2008, 04:08 PM
Dave Cogan Dave Cogan is offline
Default RV-7A Slider, Instrument Panel Tilt Angle
I am having a little trouble with an electric Artificial Horizon that I mounted on my panel. It's not going back to straight and level after a steep turn.
The instrument is a Zero deg tilt angle RC Allen instrument.
Does anyone know what is the published tilt angle of the instrument panel?
It is obvious to me that it isn't straight up and down "zero deg".
Old 07-16-2008, 04:24 PM
Bruce Reynolds's Avatar
Bruce Reynolds Bruce Reynolds is offline
Default The instrument panel tilt
is about 7 1/2 degrees on the RVs.
Bruce Reynolds
Rv-6A
Bruce Reynolds
RV-6A
Old 07-16-2008, 04:30 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Everything I've heard is 7 degrees tilt... any instrument shop should be able to set you up.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 07-16-2008, 05:25 PM
647jc's Avatar
647jc 647jc is offline
Most gyro's are available with either 0 or 8 degrees tilt, you want the one with 8 degrees tilt for an RV7 / 9. I also think Vans instructions / documents state the panel has a built in 8 degree tilt, or at least that's what I remember. I would be surprised if Van used some non-standard tilt angle in his design.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 07-17-2008, 06:22 AM
pierre smith's Avatar
Default What Joe said......
....is correct. Ours had a sticker on it that indicated that it had been modified for the 8 degree tilt...$50 cost IIRC.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
