Old 07-15-2008, 01:48 PM
rv7charlie rv7charlie is offline
Default RV-4 lower cowl 'snubber' question
The 'snubber' (best term I can think of) that keeps the cowl from being pushed up by air pressure has just broken on my -4. This is the 2nd time it's happened (2 different -4's) so I'm looking for a convenient, permanent fix. Anyone with photos to share of a reliable solution?
I've got an idea, but don't have any desire to re-invent the wheel.
This is the thing that typically mounts to the bottom of the starter or alternator & extends down & touches the inside of the bottom cowl.
Charlie
Old 07-15-2008, 01:58 PM
Sid Lambert Sid Lambert is offline
I've seen one mounted on the alternator bracket made from angle steel and covered with rubber. Sorry, I don't have a picture of it.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 07-15-2008, 03:29 PM
szicree szicree is offline
Question Snubber?
Is this something that I missed in the plans?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 07-15-2008, 07:05 PM
Don't know if it's on the plans; I bought both already flying. However, both needed them since the 1st one started breaking hinge eyes & the current one's alternator fan sawed a hole in the cowl after losing the snubbers.
Charlie
Slobovia Outernational
Pocahontas MS
Old 07-16-2008, 02:17 AM
Steve Sampson Steve Sampson is offline
Charlie - are your cowls the early ones or the later (I think its called prepegged) ones? I dont have a snubber and dont think I need one.
I would be concerned that it would cause problems because the engine moves around and would stress the cowl and its hardware.
I worry for the air box a little for this reason. It allows some movement but is it enough?
Steve
G-IKON Build log here , or Index to blog here.
RV4 #4478 - Flying since 16th June '08. First flight video here.
Circuits at my 1000' strip.
Old 07-16-2008, 12:56 PM
Both are older models, completed in '91 & '93. Both without doubt need the snubber. On the 1st plane, I noticed that the snubber was missing at an oil change but assumed it was unneeded since I didn't see any problems at that moment. Within about 5-10 hours of additional flight time, the spinner area hinges were destroyed & a couple of eyelets on both side hinges were broken off. The plane had seveal hundred hours on it prior to this, & no further issues after the snubber was replaced. There is an amazing amount of up-force on the front of the cowl at high speed.
I don't know if all RV's need them, but these two planes definitely do.
Charlie
Old 07-16-2008, 01:25 PM
osxuser's Avatar
osxuser osxuser is offline
Default Cessnas use
Cessnas use a little Lord cowl mount rubber riveted to a flange on the cowl, and that snubs up against a flat steel plate that is between the alternator and starter. They typically last about 1000 hrs.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 07-16-2008, 07:02 PM
Ahhh, excellent thought. should be much easier to fabricate than the convoluted thing I fabbed out of 1 1/2" square tubing.
Thanks!
Charlie
