For builders that have gone before:
Some builder's web sites show the brake resv./tubing connection using boiling water to soften the tube to slide the fittings together. Question: What is the sequence for 7a brake lines.
Is it: Slide the 1/4" ferrule over the tube, THEN insert the fine P63-PT3-25 Brass Insert. Or Visa/versa; insert first, the brass insert then the 1/4" ferrule?
What works best? Lord knows I've tried! Cut fingers and all.
