Hawk eye
Good catch, I know that the wings are very much a like from a structures standpoint. It was not till the RV-8 and RV-7 did van change the structural design of RV wing.
The true wing area on the RV-6 is smaller, wing area wise. That is why the RV-6 is a little more sporty (slight higher stall speed). Since the cord and span are the same and the fuselage is wider, it will take some span. You would thing the wing areas would be different.
However, I think Van's wing area is tip-to-tip length (23 ft) times the cord, so the fuselage width is included in the wing area.
Cord is 110 sq-ft/23'=4.78' (57.4")
So the true wing area is
RV-4: [23' - (24/12)] X 4.78 = 100.4 sq-ft
RV-6: [23' - (43/12)] X 4.78 = 92.8 sq-ft
The RV-4 has about 8% more wing effective area.
Why van includes the fuselage in wing area I don't know. I could be wrong but that is what it looks like. It looks like he carries this practice into his other models.
From Van's specs the RV-6 has stall speeds 1 mph higher than the RV-4 for both solo and gross weight. The listed gross for the RV-6 is 100 lbs more. Empty weight (and solo wt) is what ever it turns out to be, but Van estimates empty wt RV- 4 around 910 lbs and the RV-6 around 965lbs. Fact is most RV's are much fatter than this. For the RV-6 and especially Van assumed people would use O-320's and light props. His newer models have more realistic empty weights, but they are still is often exceeded but builders, some times by large margins. Either way RV's stall at 15% slower than a C-152. So stall speed plus or minus 1 mph is not an issue.
The tails are different. The RV-4 has elevator counter weights that go to the leading edge. The RV-6 has counter weights that do not extend as far fwd of the hinge and nests behind a tip fairing. As far as the Rudder and Vertical Stab I don't know. Call Van. From a structures and aerodynamic standpoint they are identical. However the RV-6 is known as a fast spinner. With the wider fuselage or other reasons. The RV-7 got a bigger Rudder after spin test. So the side-by-side configuration affects spin characteristics.
The RV-7 also got a longer wing span (25'), where the RV-8 is 24' span. The difference in the new wing design (RV-7/8), "plugs" into the fuselage and there is a fixed length of wing stub that interfaces with the fuselage. The spar does not carry thru to the other spar and splice at centerline (BL 0.0). The RV-4/6 design butt's at the center of the fuselage and the wing spar is spliced at the centerline, making a straight thru spar. G
