I was able to get the right bolts, studs, nuts and washers from JA Air Center in West Chicago, IL/DPA. Doug there was very helpful. They've also sold me brake fluid and other miscellaneous parts.
One of the threaded holes in the cylinder for the intake pipes has slightly damaged threads. I'll pick up a tap and tapping fluid tomorrow and clean up the threads. Then I should be able to bolt up the intake pipes, new 4 into 1 exhaust with heat muff and maybe be back flying Saturday or Sunday. I'm working some long hours and commuting over 1 hour each way each day so I don't have too much energy at night but should be ready to hit it Saturday morning.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
