Old 07-14-2008, 05:59 PM
Steve Brown Steve Brown is offline
Default Compression: too good to be true?
80/79
80/80
80/79
80/78
Is this possible?
engine has about 250 hobbs
Steve Brown
N598SD - RV9A second owner
O-320, 9:1 pistons, Catto 3 blade
KRHV - Reid Hillview airport, San Jose, CA
Old 07-14-2008, 06:05 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Default Probably not
Originally Posted by Steve Brown View Post
Is this possible?...
It seems quite unlikely. I wonder what compression checker you are using? I had a buddy who was bragging about his compression, all 80/80. Turned out he didn't know about the needed orifice in the compression checker.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 07-14-2008, 06:14 PM
Default 0.060" orifice
on second check 80/80 was more like 80/79.5
the orifice is in. when I "pressurize" without being in a cyl, pressure is about zero as air rushes out
Steve Brown
Old 07-14-2008, 06:19 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default Yes! It's possible. I've seen it.
80/79
80/80
80/79
80/78
Is this possible?
I've seen 80/80 before. I usually will call it 80/79 so it's more believable
I just helped with an annual on a Decathlon with just about the same amount of hours on it that had very similar readings.
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 07-14-2008, 06:40 PM
Mark Burns's Avatar
Default Right orifice??
Steve,
Your post (#3 in this thread) is titled .060 orifice.
Someone correct me if I'm wrong but I think it should be .040
AC 41.13-1B states:
"Engines up to 1,000-cubic-inch displacement: 0.040-inch orifice diameter, 0.250 inch long, 60-degree approach angle.
Engines in excess of 1,000-cubic-inch displacement: 0.060-inch orifice diameter, 0.250 inch long, 60-degree approach angle."
Mark
Mark Burns
Ruston, Louisiana
FFI FL-24
A&P
Old 07-14-2008, 07:09 PM
gasman gasman is offline
There should be a shut off valve at the outlet end of the gauge body right where the line connects that goes to the cly. Close that valve and crank up the knob to 80 and read the gauges. Do they read the same? If the left gauge reads lower that the right, then you will get high numbers.
Old 07-14-2008, 08:38 PM
Default Thanks Mark
Originally Posted by Mark Burns View Post
Steve,
AC 41.13-1B states:
Mark
One the body it says 0.060" orifice. I need to check part numbers to see if that's what I actually got.
If so, I would expect the drop to be about 2.25x greater with the 0.040 orifice. That should still be no problem, but I need to actually make the right measurement.
I'll be working with my mechanic tomorrow to finish up an annual condition inspection. I'm sure he's got the right one.
Steve Brown
