Old 09-11-2005, 03:17 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default "Experimental" placard size
Simple question, but I can't find the reference...I am getting the labeling and placards done on the -8...is there a specified size for the word "Experimental" that has to be visible near the entrance? I seem to remember 2", but I'm having a temporary brain reboot, and now that doesn't seem right.....
Paul Dye
Old 09-11-2005, 04:17 PM
tomsrv tomsrv is offline
Default Experimental Letter Size
Paul,
2" is the correct size. Go to FAA.GOV and print yourself a copy of the 20-27F. This will walk you thru the whole process.
Tom Emery
RV 6A N193RV
WPA RV BUILDERS
Old 09-12-2005, 06:24 AM
Mel's Avatar
Mel Mel is offline
2" minimum, 6" maximum height.
Mel...DAR
Old 09-12-2005, 08:00 AM
Ironflight's Avatar
Default Thanks!
Laser printers and clear label material are great - you can make any placard you want!
Paul
Old 09-20-2005, 03:26 PM
mark manda's Avatar
mark manda mark manda is offline
i was going to get fancy and have a mylar one with brush stroke made. ah, at eighteen dollars. I don't have time. Ordered the two pack from Spruce for $5.
tom emery-- the guys at ACS miss you. we were talking about the good old days a couple sats. ago. the teacher was still talking at 10:00am in the morning and guys at the counter kept looking back in there, scratching their heads and saying "They're just TALKING!"
Old 09-21-2005, 07:24 AM
Default Just Talking
Mark:
I miss the guys at ACS also. Back here on the east coast business is "booming". I never would of thought that it would be like this. I always took care of my students and I still do. They just keep coming. You wouldn't believe just how much AKZO primer that I have gone thru this past year priming all of these tail kits. I pay a lot of hazmat fees but it sure is worth it.
Tell the guys at ACS that Nickie and I said hi.
Tom Emery
WPA RV BUILDERS
