Superior IO-360 Horizontal FAB install
Almost got my FAB box installed. Seen some very helpful pictures. But!!
How did you cover the gap on the right side of the left baffle floor, up near the top, where the floor makes it's bend downward and forward?
I am installing a plate in that position to cover the right side of the filter to lock it in but there is a gap I can't cover due to the bend in the floor.
I am thinking of covering it from underneath with fiberglass.
What say you??
Carl Nank
Western KY Lakes Region
N39CN
RV7-A, Superior IO-360, 180HP, Hartzell, Dynon D100, D10 & HS34. Garmin 430W & 327 xp. PS Engineering 8000B audio w/3 light marker beacon. Approach Avionics Pro Hub.
Cut Instrument panel myself. I installed avionics myself. Panel is powdercoated a beautiful dark blue crackle.
